Help with what suspension to use
I am going to build this 1955 f100. I want it low to the ground and have the best ride possible. Without air bags. Plus im on a budget. With that being said Should i go aerostar, xj6 Jaguar front and rear , Crown Vic .. Im on the fence here. Any Thoughts??????????
2003 and newer
Height depends on you.............2" lowering springs are available (I have these in mine). When I first installed mine, My bumper was at 12" after the lowering springs it now sets at 14", go figure. Spring guy says it will settle (I don't think it will settle 4"). Stay away from eaton springs. There is another company that makes them that has good reviews...........coilspring.com
Might want to join the crownvic forum, lots of good info from those guys. They have helped me a lot.
Mine should be at 8" when settled. If you want to go lower you can but it requires notching your frame, much like a Cnotch on the rear. Then just move the crossmember up.
The downfall of notching is it moves your engine up as well, unless your reform the oil pan.
There are several members that have installed CV IFSs here on the Forum. There are several ways to install it (has to do with where you shim it on the frame). Also another advantage is you can move the front wheels forward (approximately 1 1/2) to center them in the wheel well. +s disk brakes, power steering, very nice ride. -s wider than F100 frame and limited wheel selection. Look for some late model Mustang wheels.
Keep us posted on what you decide to do and post pictures!!!
this is my truck
Im in Wichita Kansas. This truck had chrome running boards. Super cool truck in its day.
