1997-2000 Ford F150 Truck Power Telescoping Turn Signal Towing Upgrade Mirror Pair
VISIT US HERE FOR GREAT PRICES 1997-2000 Ford F150 Truck Power Telescoping Turn Signal Towing Upgrade Mirror Pair
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES!!!
These replacement UPGRADE mirrors are just what you need to get your truck in good working form again!
Specifications:
Both LH (Driver Side) & RH (Passenger Side)
Specifically designed as UPGRADE bolt-on replacements for Light Duty trucks
'08 and up model Super Duty style
3 stud mounting
Has the following options:
Power upper mirror
Turn signal
Turn Signal wiring will be plug and play if original mirrors have turn signals. If the original mirrors you are replacing do NOT have turn signals, wire splicing may be required.
Dual telescopic arms
Textured Black housing
Direct replacement upgrades
Built to strict quality control standards
Instructions included
These mirrors are designed to replace the factory mirrors and will install just as the originals do. They make perfect replacements with great upgrades that have good cost savings over the dealer parts.
Brand NEW fitting for the following years and models:
2001-03 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair
2004 Ford F150 Truck Heritage Model Power Turn Signal Telescoping Towing Upgrade Mirror Pair
1997-00 Ford F150 Truck Power Telescoping Turn Signal Towing Upgrade Mirror Pair
1997-99 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade Mirror Pair
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Specifications:
3 stud mounting
Power upper mirror
Turn signal
1 Year Warranty
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
01-27-2017 02:17 PM
1Aauto
07-02-2014 03:00 PM
2001-2003 Ford F150 Truck (Except Crew Cab) Power Telescoping Turn Signal Towing Upgrade Mirror Pair
1Aauto
06-10-2014 03:25 PM
1997-1999 Ford F250 Truck Light Duty (Under 8500LB GVW) Power Telescoping Towing Turn Signal Upgrade
1Aauto
04-14-2014 11:40 AM
