I've replaced input & output bearings in a T19; and also the output bearing in an NP435.
I had the lids off but didn't need to strip the transmissions down.
But I can't remember doing an NP435 input bearing; I expect it can also be changed after removing the front retainer, without dismantling except for maybe the lid.
