1976 F100 SWB
1976 F100 SWB
Year: 1976
Make: Ford
Model: F-100
Price: $3000
Mileage: 114000
Color: Blue
Private or Dealer Listing: Private Listing
Location (State): MS
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Blue
Engine: 300
1976 F100. 300 6cyl and C4 transmission.
New:
master cylinder
front brakes, rotors, bearings
rear brakes, spring kit and cylinders
fuel pump
water pump
oil pump
oil pan, valve cover and side cover gaskets
thermostat
Power steering pump and pressure hose
all new battery cables and solenoid
PCV valve
Tires 31-9.5-15
New Aluminum radiator
Work thats been done:
Floor boards have been cut out and replaced and also the floor has been rhino lined
Fuel tank cleaned out and all new fuel hoses
Bought new fuel sending unit but was garbage so bought a used one from benbuilder and now it works fine
Carb has been rebuilt
Motor was replaced- the original ran but made some noise so replaced with an engine from a 79
Swapped engine to durasparkII ignition.
Only rust that is on the truck now is in the hood and I have another to go with it. Also in the bottom of the doors but my body guy was going to cut it out and replace it. The bed has some surface rust but thats it. I have a non cracked dash pad that I had painted and also door panels that are also painted the same color. The seat still needs to be redone.
There is no where I have been afraid to drive this truck, it runs out fine. The ONLY reason I am getting rid of it is because I found a 71 F100 that I want. I like the body style a little more.
If you are interested send me a message. Oh I am asking $3000 but is somewhat negotiable. I can email updated pictures....thats all I have on here.
Truck is sold.
__________________
TS_Hampton
03-18-2013 04:55 PM
SuperDutyt52
10-29-2010 12:20 PM
