4 wheel fun....gearing is awesome!!!
So yesterday on my way back from the store I pulled into a large empty field. I wanted to engage the 4 wheel drive to give the transfer case some use and make sure everything was working properly. I don't hardly use my 4 wheel drive....I think I have actually needed it twice in the past year since I bought the truck and it was not because I was stuck but more so to keep from tire spin and tearing up my friends yard lol.
The past 2 times I used it I used 4WH....I have not used the low at all. Well I pulled into this field and engaged the high side and just drove around did some big figure 8's just to make sure everything was in order. I climbed a few hills just to play.
Then I switched to the low and the gearing is crazy......just for fun I stabbed the throttle and holy crap.....this truck surprised the hell outta me. The gearing is so low and the engine makes such good power it pined me in the seat............lots of fun
Low range reduction is 2.72:1 in low, which is not bad for a modern 4x4 (although the NVG 271 / 273 t-cases in these things have been around for a long time)...but be advised you total reduction is based upon three things...the ratio of your transmission's 1st gear, the transfer low range ratio, and your axle ratio. Fortunately the 6-speed transmission in these trucks has a nice short 1st gear ratio. But a Jeep Wrangler Rubicon has a 4:1 low ratio gear, etc.
F150newf
11-24-2004 03:23 PM
fordper4mance
05-24-2004 10:01 PM
