87 stepside on a 60 F100?
The box dimensions for the 87 stepside bed are very close to the dimensions of the styleside I have on there now.
I know the mounting points changed after 73 but are there any significant issues with mounting this bed on my 60? I would want to swap out the boxy wheel hubs for the older style eventually but I can get the bed cheap and there are absolutely no pre 73 step side beds around here that do not have terminal cases of rust.
Anyone else done a similar swap? If it is just a matter of making my own mount points I can do that easily enough.
Hardest part is the unbolting of the bed. That may require a torch or plasma cutter if the rust is bad enough
Amphihauler
05-15-2017 02:07 PM
iibacardii
07-26-2014 05:10 PM
Kingcharlesii
07-03-2002 12:54 PM
