High Idle mod with a twist
Hello everyone, this is an idea I came up with about 2 years ago, ended up ordering the parts but just never got around to it. It's essentially an Arduino hooked to a potentiomiter with some pretty colors thrown in. I had plans to use it to remotly activate the high idle after remote start. Anyway here's a little video.
<iframe width="560" height="315" src="//www.youtube.com/embed/VwhaygEeXK8" frameborder="0" allowfullscreen></iframe>
To get the trucks to or close to operating temps in cold weather...before you operate them. On my Dodges it was enabled in cold weather states before the sale. In warm weather states you had to have it enabled. High idling them helped prevent cylinder wash when idling them all day in a field or over night. This function is obviously different than the PCM high idle that senses cold temps and high idles at start up.
Cool stuff. I have various Arduino's sitting on my bench. Haven't done anything truck related with them yet but I have a battery/current monitor for my trailer that sends data on the network to a Pi/touchscreen unit. Working on some other applications too.
The things are cheap enough that you can have a bunch of them. Just ordered more Nano's & NodeMCU's, just have to wait a month for it all to get here from China.
Factory alternator(s) can give pretty much full output at idle. I have high idle mod and it didn't provide any measured/observed benefit to winching. high idle does sound cool....
Granted, if it is in park, the truck will high idle on its own, which is why I haven't done the mod. I've remote started it and the truck high idled, then it dropped down, and because it was -22F out, it didn't take it long to go back to idling up... However, the cabin doesn't get warm until you drive off, even with the rapid supplemental heater. (The RSH REALLY REALLY helps though).
Tested it out tonight. Thinking I'll add a temperature probe and set it to engage automagically when it's cold out.
https://youtu.be/ZIZJB8Issec
