Severe backfire, no power
Yes sir. Beyond a shadow of a doubt the firing order is correct.
I also plugged the crossover tube hole in the back of that head. It's allot quieter now but that's about it.
I started it, let it idle for a couple minutes then got on the gas and it just pops through the intake.
Ran KOEO codes and got 312. Insufficient egr flow. Well I know I've got a disconnected vac line for the egr but it doesn't change how it runs. It has this problem when it was hooked up. I had it off because I am going to replace it.
on
It is starting to sound like you probably have a bad PCM all right, the electrolytic caps degrade and eventually short out and explode which can cause damage to other components. These caps have a typical useful life of about 20yrs give or take so it's not an uncommon problem in trucks of this age. The manufacturer certainly never expected these vehicles to still be operational 25yrs later.
You have a MAF meter on a '93? Do you mean the MAP sensor perhaps.. little black thing mounted up on the firewall?
OK is there a way to test the computer or can I remove it and open it up for physical signs of inoperability?
Thank you!
on
Yes remove it and look for obvious damage inside, be sure to disconnect the battery first and also inspect the pins in the connector to see if any are bent or pushed back. Also take down the box code info on the PCM connector or take a picture of it so you can search for another if this one turns out the be in bad shape.
Ok so I removed the PCM. The connector looked it good shape although Ill still clean it up and grease it up prior to installing the NEW computer.
Yes, that's right. I opened it up and at first I didn't see anything obvious and I got discouraged and then I glanced at the electrolytic capacitor (one of the 27micro farad, 24 v ones) looked like it had leaked? The stamped paths on the circuit board were irreparably damaged and so, that most certainly was an issue in the engine running!!!
Is this something that happens? What is weird Is that the PCM says Remanufactured Original Equipment on it. Who know when it was installed. no dates or anything on it.
My question about getting a replacement. What numbers on it do I pay attention to? I see some fairly obvious raised alpha-numeric that looked like it could be a part number but I also saw, very faintly another, barely stamped in there that looked like it could also count.
I saw one on ebay and the guy said it would work with my truck as long as the truck, year, engine and transmission would match, it was fine. Is that the case? Or do I need to search for specific part number?
Thank you guys for the great help! For the first time in two months on this truck I am finally feeling encouraged
#28
