95 f250HD 5.8l CEL
95 f250HD 5.8l CEL
Run the code and comes up with bank 1 lean - 0174? (not at the truck to double check but it was bank 1)
No other codes, and at times it really has trouble accelerating, it almost feels like it is gonna die with wide open throttle, hear/feel a little pop and takes right off. There is no MAF senor on this truck
O2 sensor???
O2 sensor???
O2 sensor???
O2 sensor???
I ask because a P0174 is a OBDII code, "System too lean Bank 2"
174 is a car only OBDI code "HEGO switching time slow" (same code would be 175 for trucks) and both of those CM.
That is according to my OBDII software and OBDI book.
Where are you getting your codes definitions from? reading them with?
tankhokie
09-15-2003 08:28 PM
