Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Has anyone changed the engine mount - 3.0L?
Old Mar 13, 2014 | 05:38 PM
sundvl76's Avatar
sundvl76
2005 Mariner 3.0L
I need to change the engine mount located on the passenger side of the vehicle. Has anyone done this? The shop manual shows using the "special tools" to lift the engine 0.98". This thing is a real Rube Goldberg lookin' 4-piece thing, and I'm wondering why I can't just lift the engine an inch with a padded floor jack under the oil pan. (I can't imagine that "real" repair shops would buy this tool from Ford!)
Another question is: Is this the primary isolator for the engine/transmission? There appear to be 3 mounts, however this one on the passenger side is the only one the shop manual gives instructions for changing.
Any experience here?
Thanks!
Last edited by sundvl76; Mar 13, 2014 at 05:40 PM. Reason: left off vehicle and year
Old Mar 16, 2014 | 01:56 PM
idfergusson's Avatar
idfergusson
When I changed the alternator on my daughter's 2005 Escape I unbolted the passenger side motor mount and jacked up the engine a bit for more clearance and it didn't appear to hurt anything.I used a piece of 2x6 lumber about a foot long in between the jack and the oil pan to spread out the load.Someone on another forum cut two pieces of plywood to fit on either side of the oil pan and put a brace across the bottom so they could lift against the block rather than the oil pan which seems like a good alternative as well.
Old Mar 16, 2014 | 06:06 PM
sundvl76's Avatar
sundvl76
Thanks, good idea re: the plywood. I would rather not lift w/the oil pan if I can avoid it. Turns out, after more careful reading of the shop manual, the engine only needs to be "supported" not lifted, but still there will be pressure applied somewhere. I could also lift / support with a floor crane but that seems like a lot more trouble than necessary.
Old Apr 4, 2014 | 10:37 AM
crazyrwe's Avatar
crazyrwe
I had the mount go bad but was replaced under warranty. The vibration was pretty bad.
poffutt
1978 - 1996 Big Bronco
Mar 31, 2006 11:44 AM
sharkdance
Mar 25, 2005 09:36 PM
ken351C
3.0L V6
May 3, 2004 07:44 AM
Bargod
Mar 15, 2004 01:28 PM
dbarracuda
Sep 21, 2002 05:24 AM
