slow starts
Old Mar 13, 2014 | 05:28 AM
brandon.edwards's Avatar
brandon.edwards
slow starts
So i had a bad injector, a result from a bad ficm, which was the result of low voltage (bad alternator) and I got the injector replaced, batteries a couple months ago, and a DC power alternatoer. I have good voltages on the ficm power (main/logic on scangauge) but the sucker still starts slow in really all conditions. I'm going to have the batteries tested Saturday and start there, but I didn't know if you could provide any knowledge or insight on why I'm starting slow? I thought maybe more injectors bad. I haven't run the truck since Monday and I went ti fire her up today and I had to hold the crank pretty long as it cycled and got into its rpm pattern to start. Idk what else to think other than batteries run down a little. But I'm getting 14.6 volts after the delay.
Old Mar 13, 2014 | 06:11 AM
npccpartsman's Avatar
npccpartsman
Check to see what cranking RPM's are. It could be the starter getting tired.
6.9lbluenose
Jun 9, 2019 07:48 AM
BigBlueX
Oct 27, 2015 10:23 PM
runmaster
Oct 25, 2010 07:38 PM
Chevy 6.2D
Nov 5, 2009 07:50 PM
02fpstroke
Sep 28, 2008 02:30 PM
