SuperCab 4x4 Resto-Mod Cummins Swap Build
#631
4 x 4 build
Hi Bryan
Definately a nice custom job on the tail gate handle and a perfect match to the door handles. I noticed about half way during your build you made a new dash’s. Real nice job especially the surrounds. Thought I would share a standard Aussie one and a mates customised one.
Custom job
Standard instruments
Custom job
#632
on
The tailgate handle is an awesome feature - but I can't recall why you're doing it.
Did you want that "shaved" look but still have access to drop the gate mechanically?
Possibly adding a locking mechanism to the exterior of the tailgate might have been an easier venture - but then we wouldn't have ended up with this awesome update
#633
I did it mostly for the security. I thought about just adding a lock cylinder to the exterior, but then decided to go full custom. If I were to do it over again, I would have just gone with the lock cylinder to be honest.
#634
#636
#637
#638
Well, I found my seats. I had a few criteria:
Here are the seats getting outfitted for new upholstry
I definitely have to apologize here, once again I got carried away with heads-down work and neglected to take pictures of the process of fabricating the seat mounts.
The trick was to build brackets that mount the rearmost slide position far enough back for my height, but can slide forward far enough for passengers to be able to access the back seats.
Anyway, here are the completed brackets.
Driver side
Passenger side
And here is how the seats turned out. Fox Brown leather with black stitching, French seams, and diamond inserts. This is the passenger side.
- Late-model comfort
- Adjustable headrest (I'm 6'3" and I don't like the idea of whiplash caused by a rear-ender)
- Manual adjustment (I hate power seats)
- 80/20 bucket seats with flip-down center console seat
- They have to physically fit in the truck (i.e. width, seat height, etc.)
Driver side
Passenger side
#639
Definitely not as far as I'd like, getting in the back is a bit of a pain. I want to get this truck to a point where it can be driven, then I'm going to look into modifying the seat mechanism. Hopefully it will just require grinding down or relocating a stop. Haven't looked into it yet.
#640
#641
Shifter Bezel
Ok, that's way too long without an update, sorry. I made a bezel to cover both my transmission shifter and my transfer case shifter. I started by cutting a square of aluminum plate just big enough to cover the relocated shifter holes in the tunnel cover.
Next I made a very simple curve to follow the outside edge, leaving room for carpet thickness. I did this because the T/C shifter is so close to the edge.
Then I taped a piece of paper to the top of the tunnel cover to trace the holes to make a template.
After that, I cut the holes out and transferred the template to the aluminum plate. Then I traced out the design that I wanted for the bezel.
Here I'm starting to cut the piece out. As you could probably tell from the photo above, I misjudged the overall size and cut my aluminum plate a little too small. I had to extend the T/C portion of the bezel towards the bottom by welding on a small scrap section to it.
Here is the bezel all cut out
And here it is with the mounting holes drilled. I will then transfer these holes to the tunnel cover and install nut-serts to mount it. I will also countersink the bolt holes so that I can use flush-mounting hardware.
Here is the tunnel cover with holes transferred and nut-serts being installed.
I decided to go with a texture black on the bezel to match some of my other trim pieces, I like the way it looks. I think it will be set off nicely with polished stainless hardware.
#645
