!!!Help!!!-Middle of New Injector Job-Not going well
So Im finally doing this job now.
Smoking like a champ....
T500 HPOP
All 8 AD INJECTORS
HPx
FRx
Fuel Bowl Rebuild.
I did Gps under a year ago while working on the everlasting cold start issue with AutoLite's because I didn't know anybetter at the time.
Now the second GP back on each side wont come out. It is past the thread out but im assuming swollen? I was able to get DS out with slide hammer without it crumbling but PS is still stuck in head.
WHY?
Is it normal for all 7 so far to have oil on them? (I pulled Injectors then Gp's)
Any secret ways to get this GP out without pulling head?
Should I re torque Rocker arms or check lash while in there?
I have pulled 2 rockers to get in with slide hammer. What spec to tighten to?
Yes I used hand vac in holes, Unpluged IPR and cranked a few times before installing New Injectors...
WTH? Why Me Again ?lol
T500 HPOP
All 8 AD INJECTORS
HPx
FRx
Fuel Bowl Rebuild.
WHY?
Haggs, I have no experience removing stuck glow plugs, but I found this and it may be the best insurance into not removing a head if you happen to break the plug tip off:
"Glow plug removal article"
Good luck
Good luck
It is normal for oil to be on the GPs as they are removed - I think because there is oil around the top of the plugs and as you remove them, they get coated. If you blow the oil out from around the plug heads with compressed air, I bet they'll come out dry, but I never bothered.
Dang those autolite GPs.
You have already forced one out... did the whole unit come out, or are pieces missing? If complete GPs don't come out, I'm not the expert on this but I believe you're done in. Autolites create a huge "Oh crap" for the owners - they are dreaded for the very reason you are faced with right now.
The PS, not so much. My crows foot is soft and keeps bending. Im looking for a nice machined steel one now but no luck so far.
And Im sure when/if it comes out it will probley leave pieces and all this time will be for not as Ill have to pull head anyways.
All that testing I had to do to diagnose the bad #8 2 months ago probley overheated these cheap ars autolite ones.
White Smoke
I'm seeing white smoke coming out the exhaust pipe. A few drops of looks like oil on the cement. It has a slight mis , no blow by coming from the oil filler cap and same from the anti freeze reservoir. Looks like a enjector?? Does anyone know of a good PSD mechanics in the Shreveport area? Oops forgot a 05 with 60 k on it
Received 3,697 Likes
on
me personally I would not leave it in there after having hit it with a slide hammer, you don't know what damage that tip has on it.
some have had luck with a drill spinning it and spraying penetrating oil on it while spinning. working it up and down and wearing the swollen part off. the only problem is the shavings going through the engine after you get it out, but I guess shavings are better than a glow plug tip.
