4x4 issues 2004 350
Old 04-01-2014, 07:45 PM
Tedesco's Avatar
Tedesco
Tedesco is offline
4x4 issues 2004 350
My light does not come on when I switch to 4x4 and the truck does not go into 4x4 when I manually lock them from the hub
Old 04-01-2014, 09:02 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
Check your vacuum lines going to your hubs.
Old 04-01-2014, 09:50 PM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
Possible solenoid out for transfer case... I have read about it but dont have it down enough to give you proper direction. Hopefully someone with more exp will chime in soon.
also check fuses JIC
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old 04-02-2014, 06:53 AM
78fordman's Avatar
78fordman
78fordman is offline
Engage both front hubs and get under the truck and see if you can turn the drive shaft between the transfer case and the front axle. If you can you have a hub not engaging. If you can't there is something going on either with the shift motor on the transfer case or something mechanical inside the transfer case.
BigBlackF-250
1999 to 2016 Super Duty
03-17-2015 08:25 AM
metalhead132
1997 - 2003 F150
07-03-2011 12:47 PM
ggravette
12-12-2010 03:52 PM
63DH8
03-29-2009 10:59 PM
EaTmYtAiLpIpEs
20
07-03-2007 09:48 PM
Quick Reply: 4x4 issues 2004 350
