Humming/ Vibration Noise
Still having an issue but was not able to find old thread .... This started after replacing front hubs and switching to new tires 275/70R18 (Take offs from my dad's 2010). Truck is in profile 01 F350 4x4 CC LB. Shop that did the hubs checked them after I mentioned noise and said they were fine. Tightened up-pipes and replaced intermediate drive shaft bearing in attempt to locate cause of sound.
The sound: It sounds like a loud grinding/rubbing sound. Medium to low pitch, does not sound like metal on metal if that makes sense. I have seen no difference in mpg or engine performance. Checked to make sure hubs are unlocked as well. Noise occurs 50+mph when lightly on the throttle. I can make the noise persist with pedal control and it gets increasingly louder as you go further and further above 50mph. No noise when off the throttle or 25%+. I would say in the 10%-25% range is where I can control it and just keep it there as long as I am around 50mph.
Its been probably about a year and it has not gotten better or worse since it started. I need to replace ball joints but don't think those are the cause. Any thoughts on what it could be? To me, the sound is coming from in front of the firewall and I would say to the left side. Don't hear anything while braking, tow/ haul mode makes no difference either. Might be able to feel the vibration but the truck definitely does NOT shake when the noise occurs.
Lift is a 6" tuff country with front leafs and rear blocks. Shocks are probably bad and need to be replaced as well. Truck is completely stock with the exception of a K&N washable filter.
Sorry for the lengthy question, just trying to give as much info on what I and others have done, felt, and heard to help eliminate possibilities.
Any help/ thoughts much appreciated
A bump, plus questions...
OEM 2010 tires or ? ABS hubs? Does 4X4 work normally? How bad are those ball joints? Sound the same when 4X4 engaged? Or u joints: put it in park and crank the e brake on the rears; give the drive shaft a twist and see if the u joints have some slack.
If you clean/oil the K&N religiously you're good, but if not, ditch it.
No slack in the U-Bolts. I need to take a picture but there is what looks like a rubber ring (roughly 1/2" wide by 2.5" diameter) on the inside of the knuckle on the left side. So it would be to the outside of where the hub actually turns when you turn the wheel. Doesn't seem like that could make the noise but could that indicate something? I also noticed what looks like a broken vent or something from the hub. FYI my dad (Original owner of my truck) is one of the its just a truck so it should run forever about maintenance .... So I'm slowly working on getting everything up to snuff. I'll post pictures this afternoon when I get of work.
You say you replaced the intermediate bearing. Do you have a drop spacer under the intermediate bearing? A lift that tall needs one to correct the driveline angle. I had to install one with my 4" lift, I made mine and installed it and my vibration went away. If you don't have one you need one or you will get driveline vibration.
Hmmm .... I did not install a spacer and not sure if there is one there. I'll have to look. I will be dropping the truck back to stock ride height once I am ready to start making modifications so I'll have to keep that in mind ....
As far as the ESOF vacuum tube, anyone have more info? Read a few things on it but nothing about getting a grinding/ vibrating sound like I am. Guess it wont hurt to replace the tube anyway ....
If there is no spacer I would bet that's the cause of the vibration. My spacer is home maid, I'm going by memory so it's aprox 1" thick 2" wide and 6" long piece of aluminum bar stock with a hole in each end for the bolts. It gets put under the bearing mount to lower the bearing. Just need longer screws.
When the drive shaft was apart was it greased? If there's no grease it will create a noise that you'll swear is going from the front. Which is one more reason I opted to have a grease zurk installed when I had my new ds made. No more pulling the ds to grease the splines anymore.
