Would anyone use new heads like this?
Old 03-09-2014, 11:22 AM
tude's Avatar
tude
tude is offline
Next was going to be roller rockers but decided after $1300 I better stop for the day.
Old 03-09-2014, 11:25 AM
earthquake68's Avatar
earthquake68
earthquake68 is offline
The flip side to the argument is whom did you talk to at the place you ordered from? What kind of questions did you ask about the quality and completeness of the heads? Have you looked at your old heads this closely to see if they are made the same way?
Sometimes you have to be the one to do the leg work to see if what you're looking at on the computer screen is what you're going to get in your shop.
No, it shouldn't be that way, but sadly it IS that way these days.
Old 03-09-2014, 11:33 AM
tude's Avatar
tude
tude is offline
Head bolt holes
Part code
Old 03-09-2014, 11:36 AM
tude's Avatar
tude
tude is offline
I order them off their website without calling. Lesson is now learned. I've never noticed valve cover bolts going into intake runners on anything before.
Old 03-09-2014, 01:36 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
1967 Turbo 6.9 is offline
All CJ heads have had that valve cover bolt hole into the intake port from day one.
Old 03-09-2014, 01:46 PM
Toodugs's Avatar
Toodugs
Toodugs is offline
Hmmm
No kiddin, sealer on something reliant upon pressure, heat and vacuum. Alrighty then, like I said I was in that industry in the 80's and maybe I'm talkin outta my a**. I'll bow to those with more current experience than I.
Old 03-09-2014, 02:05 PM
1967 Turbo 6.9
the original 429 CJ was that way
Old 03-09-2014, 05:20 PM
JP3's Avatar
JP3
JP3 is online now
Not a big deal. Seal it up and never think twice about it.
M-6049-SCJ is the part number for a bare head.
M-6049-SCJA is the part number for a complete head with hyd cam springs.
M-6049-SCJB is the part number for a complete head with solid roller springs.
Old 03-09-2014, 06:50 PM
1967 Turbo 6.9
Make sure and update this when You find out if Ford is making good on this heads. When I got home I unboxed the latest SCJ heads and they are just like Yours two of the rocker studs are drilled into the ports. I don't see this as problem I've ran heads with worse looking things in the ports.
Old 03-09-2014, 07:58 PM
tude's Avatar
tude
tude is offline
Ill update it in the morning after I call.
I really thought I was ordering with valves though.
Old 03-10-2014, 06:12 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
If you do decide to send them back and get ones with valves, consider buying P51 heads from Jon Kaase. He is the man that designed the heads you have in your hand, and when an issue came up with Ford over them he decided to REdesign them better. They flow almost 400cfm out of the box.
BUT as noted, the valve cover bolts are still going to be into the ports. I don't recall about the rocker stud bolt but remember your dealing with revised ports that are raised slightly for better flow which leaves less room for threads so yes they can extend into the port. Seal the bolts with a sealer and don't worry about it.
Old 03-12-2014, 11:08 PM
tude's Avatar
tude
tude is offline
I did some calling, never could figure out where "ford racing parts 123 " was to ask about the valves. But I did get ahold of a ford racing dealer/installer shop and he said to just use thread sealer and its normal.
Either way I don't think it would be a good idea to build them that way but I guess it is.....still trying to figure the valve situation out.
  #28
Old 03-13-2014, 08:21 AM
JP3's Avatar
JP3
JP3 is online now
I have bought valves from: SI VALVES- ANTIQUE/VINTAGE ONLINE CATALOG
They were SUPER helpful and their prices are good.
  #29
Old 03-13-2014, 12:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
X2, I've used SI Valves too. Great on the phone and good prices.
  #30
Old 03-13-2014, 02:48 PM
monsterbaby
valves are pretty easy to come by. The above link might be ok (never used them so don't know them) Scot at Reincarnation auto can get them for you, Or Lem at BF Evans ford etc. Even Summit racing.
I have used Ferrea valves in the past (and if I recall they are what Ford uses in those heads anyway) Racing Engine Valves | Ferrea.com
leeinphx
Modular V8 (4.6L, 5.4L)
04-08-2019 02:27 PM
Nicholas B
06-14-2015 09:28 AM
DManikowski
Ford Truck Parts for Sale
01-16-2015 10:28 PM
capelo
11-24-2013 03:11 PM
sandyrun
12-26-2009 06:18 PM
Quick Reply: Would anyone use new heads like this?
