Where to buy clutch kit?
Well, looking at my catalog the 11" clutch is part #:81T-7550
The pressure plate is: COTT-7563-A
Is that what you have?
Looking at partsvoice.com it says Antique Auto Supply and ColectorsAutoSupply.com have the clutch and Bob Allen Ford and Green Sales have the pressure plate.
How many splines and what size hole do you have? Orielly has one with 10 tooth spline and 1 1/16 shaft. I think I have more than 10 splines on mine though....
Hopefully our parts experts will be along shortly to set the record straight.
Ditto on a quality rebuild. Also worth having the flywheel and PP balanced, I had one done and couldn't believe how much metal they had to add to the PP. Like an inch of 1/2" bar.
You can also change to a ball-bearing pilot bearing. Some people prefer the bushing but I really like the ball bearings. National Part # 203S Bore=0.6693", Outer Diameter=1.5748", Width=0.4724"
It's a direct replacement and doesn't cost any more than the bushing. Many kits come with it.
Not sure what a diaphragm PP looks like but it was thin and where my PP has the three rods for actuating the disc the one they brought in must have had 25 little prongs around the opening of the PP. It did have 10 splines.
I dunno if you can even get a new Long style (3 finger) PP at Napa anymore, All the ones I have seen are a hybrid....diaphragm clutch with a Long style bolt pattern
Fwiw those Ford 11" clutches are all the same up thru 1964. After that the spline count changed. Might expand your search a bit.
Clutch Kit
HELLO!!!!!!!!!!!!!!! I got my clutch kit from Vanpelts Sales there contract is vanpelts sales.com there phone is 1-800-299-7496. I also got transmission parts for my HD 3 speed 1950 F-1. Are great people to work with much help and great service hope this helps. P.O. Box 327 Batavia Ohio 45103
Last edited by little ones garage; 03-09-2014 at 10:29 AM. Reason: for got address
I'm surprised your F-100 has an 11" clutch. Which trans do you have? A 10" clutch is more common. How did you determine that you have an 11"?
I went to NAPA in '07 to get a new clutch (a 10"), and they brought out the diaphragm clutch. I decided to try it, and have had very good service from it. It is noticeably smoother than a Long clutch, and I don't work it enough to care about any difference in "strength". My understanding at the time was that it is a Y-block service clutch. The 11" diaphragm may be worth trying, just make sure it clears the BH, as mine was very tight.
