I HAVE A 93 BRONCO XLT WHICH NEEDS HELP IN THE DASH DEPARTMENT, DOES ANYBODY KNOW WHERE I COULD FIND A NEW ONE? IT SEEMS THAT THEY STOPED MAKING INTERIEOR PARTS IN 91, IF ANYONE COULD HELP IT WOULD BE GREAT.
Are you looking for the entire dash, or just the cluster (the part with all the guages)?
You can find clusters in the junkyards pretty easily; you'll have the tach/no tach option, and if you go with the tach, make sure you get one with the same number of cylinders that your truck has if you're not going to transplant the tach module from your old cluster. You can use the F-series clusters as well. And if you get the diesel cluster, you'll have to move your fuel/charge module over from your old cluster.
As far as an entire dash, that may be a bit harder to come by, but you'll still be looking in the junkyards.
Originally posted by 93NVELIN IT SEEMS THAT THEY STOPED MAKING INTERIEOR PARTS IN 91.
I just had my '92 broken in to and they tore up the dash pad around the stereo (didn't get the stereo...stupid criminals). They replaced the dash pad from Ford brand spankin' new. The components are the same for every 92-96 Bronco and F150 and 92-98 F250's and 350's. With the slight exception for the hole next to the headlight switch for the rear glass in the Bronco, all these dashboards are the same. So boneyard shopping shouldn't be too difficult but I KNOW that at the very least, the dash pad is still available from Ford.
