vacuum line problems
Old Mar 4, 2014 | 02:41 PM
lightning17's Avatar
lightning17
So i made a new vacuum can, looked over a few things and theres one line out of place. At the vacuum can, only one of the two lines (red and black i believe) that are supposed to be there are hooked up. Whoever worked on the motor before took the line from the tree that comes out at the top of the upper intake (3 lines) and hooked it up to the vacuum can. I was wonderin where the line from the upper intake is supposed to go. Truck's a 94 302 with an MAF sensor, no map sensor.
Thanks for the help,
Jp
Old Mar 5, 2014 | 11:44 AM
lightning17
Anyone? I've looked at a ton of other pics and havent found anything rigged the same as mine. Would i just be able to block off that line?
Old Mar 5, 2014 | 01:19 PM
Krisverde's Avatar
Krisverde
Maybe post some pics of what you are describing.
spooktn
1983 - 2012 Ranger & B-Series
Apr 14, 2018 12:55 PM
tofino
Oct 12, 2014 04:19 PM
The Terrible Blob
Mar 10, 2014 10:56 AM
msinger
Oct 7, 2003 06:53 PM
