what the$%^ is in my heater hose
not sure if picture link works, anyway it's a piece of the hose that runs from bottom of radiator to heater core with what looks like cat crap coming out of it. leftover sand from the casting, maybe? I'm starting to doubt the PO's reassurances about maintaining the SCA levels. at 375k miles, should I be worried? What, if anything do I need to do to get all the kitty litter out of my block?
Received 3,090 Likes
on
a friend of mine NEVER uses a chemical flush in his coolant systems primarily for this reason. He claims flushing the coolant system with chemicals (as opposed to just plain water) just allows for the extracted gunk to accumulate in hard to reach areas. I never believed him (he's a bit paranoid), but maybe this is some evidence of that.
Even then it would still be a last resort
I have never seen this before but it sounds like the sludge the coolant tech, from the coolant company, spoke of when mixing SCA's with the wrong kind of engine coolant. The tech I spoke with said if I was not positive which coolant I had in my system I should remove the radiator fluid and start over fresh.
Additionally, most of the SCA charged coolant will only work with up to approximately 25% compatible non SCA coolant (Check the directions).
Why does your radiator hose originate from the bottom of the radiator?
I had this stuff in my heater core one time I just put the garden hose on one end on full blast one side and let it run until it was clear coming out the other end. heater worked better after.
