Rear springs and over load bumpers
I have a f100 but looking at this set up it looks like something more. Are the springs normaly like this? There are additional 1'' block that goes under the spring. the truck also had what I call adjustable bump stops to add support for heavy loads that were placed on both sides. are they stock or after market. I only want to use what is needed to make the truck a easy cruiser. I am flipping the axle and only want what is needed.
On my '56, I did the axle flip and removed 2 leaves from the pack along with a C section. It softened the ride somewhat and lowered to truck a bit more.
Steve
I agree Steve, I have a notch kit on the way. I was going to remove the over load springs and adjust from there. I want a soft ride. I have other trucks for hauling. 5'' in rear. I have the front axle on the way to do a 3'' drop. Not sure how it will turn out. I'm hoping the truck will be fairly level. but I can adjust from there. I just need to get an engine in it first..
1963f100nv
07-07-2018 12:30 PM
SonyResendiz
09-07-2014 11:21 AM
matt2491
36
12-19-2008 06:34 AM
fun98
16
05-06-2006 10:08 AM
