Sloppy axle on drivers side
I have been getting a weird grinding / vibration on the drivers side for a little bit now and have just narrowed it down to slop in the drivers side axle..
Is there a bearing on the inside of the axle tube and if not what supports the axle ?? only the hub assembly bearing ?? and its needle bearing ?
Maybe a bad U joint will cause this slop as well ?
thanks for any advice
Kyle
Kyle
I have replaced / serviced them before..
But more specifically what supports the axle ?
Kyle
Ok guys..
Main assembly bearing gone in 1 side..
Changed..
other side needle bearing and seal went..
Changed both and axle had a little wear right before the spline. I think it'll be ok though since its clean at the bearing support..
all fixed.. but gonna replace the hub assembly bearing as well when I get 1 ordered..
truck has 175,000 miles..
Kyle
Changed..
Kyle
binuya
20
09-30-2009 09:39 AM
Madmaxz
34
08-11-2008 09:33 AM
