Replacing most of A/C system. I have ????
Old 02-28-2014, 06:44 AM
joegeds's Avatar
joegeds
joegeds is offline
My a/c compressor burned up on me. So I will be replacing it. The manual says that any time the compressor is replaced, to replace the accumulator/ drier, and evaporator core orifice should be replaced as well. So far, so good. In reading about adding new refrigerant oil (YN12B) to the system, it has specific instructions on how much to add for each component based on how much old oil is drained from each component. I get the instructions for the compressor and accumulator/drier. Then it says that if you replace other components like the orifice or lines, to add 2 additional ozs. If I'm replacing orifice and flushing lines, do I add 2 or 4 ozs? Also, to flush the system, do those cheap flush systems from auto parts stores work we'll enough (they basically consist of a pressurized canister and small hose), or do I need to use a real a/c flusher? And if so, are there places that rent them? TIA
BTW- 96 F150, 3.9L straight 6 Eddie Bauer
tkerkela
09-16-2016 12:25 PM
Bremsen
06-13-2011 08:35 AM
lippsenator
06-19-2009 03:02 PM
LIGOOMBA
06-12-2009 11:46 PM
Quick Reply: Replacing most of A/C system. I have ????
