Put this transfer case in after planetary wore out because of pump failure in the previous transfer case. This one is pouring fluid out of this hole. Dont recall any place for it to come out when i had it apart but it has been a while. Is ther a seal or something there? Can i access it from out side with out splitting the case? Never had one do that.
Yes thats where the electric shift motor goes on the electric shift ones. I want to say its cast closed on the manual shift ones. But maybe there is a plug there thats leaking?
Well, y'know, if that's all it is... Make yourself a plug and JB-weld it shut! :P
