Lighting issues
Old Feb 24, 2014 | 12:23 PM
Jklnhyd's Avatar
Jklnhyd
Lighting issues
I have put this off for some time. But reading other lighting threads, guess i will jump in. I know that my blink cam is not working, when i signal left, i have to kind of gently push the handle back up a bit to get the dash light and front bulb to blink. Im ok with that right now. My issue is:
1) dash lights- not illuminating
Old Feb 27, 2014 | 08:10 AM
Jklnhyd's Avatar
Jklnhyd
I wont be able to do anything on this for a few days because its raining. Hopefully someone has time on Saturday afternoon or Sunday.
Old Feb 27, 2014 | 08:23 AM
fmc400's Avatar
fmc400
MSEE
When you get back out to the truck, turn the headlight switch on, turn the **** counter clockwise until just before it clicks into place to turn the dome light on, and measure the voltage on BOTH sides of the dash illumination fuse. Report your results.
Old Feb 27, 2014 | 08:28 AM
Jklnhyd's Avatar
Jklnhyd
Will do tonight, ty.
Old Feb 27, 2014 | 06:14 PM
Jklnhyd's Avatar
Jklnhyd
Top 11.40
Bottom 0.00
I put a 3amp fuse in there the other day, and it is blown.
Old Feb 27, 2014 | 07:03 PM
fmc400's Avatar
fmc400
MSEE
Your multimeter measurements support your claim that the fuse is blown. Next you need to figure out what is causing the instrument lighting circuit to pull too much current. The most common cause for this is someone installing a radio incorrectly - the BLUE with RED stripe wire (dash lighting) paired in the radio power connector is often mistaken for ground. The dash lights find a sneak path to ground through the speakers, and the fuse blows.
That's just the most common cause; if that's not the case for you, the root problem is the same. You need to find the short to ground.
Old Feb 27, 2014 | 07:19 PM
Jklnhyd's Avatar
Jklnhyd
Beautiful!!
Yes, i used it as ground.
Old Feb 27, 2014 | 07:24 PM
fmc400's Avatar
fmc400
MSEE
Is the next step not obvious?
Old Feb 27, 2014 | 07:28 PM
Jklnhyd's Avatar
Jklnhyd
Well, i dont want to interrupt like everyone else, lol.
Disconnect the red/blue and connect it with the illumination on the radio harmess.
Get a wire with loop connector and ground it under a bolt
Is there a better ground that i can tap into?
Old Feb 27, 2014 | 07:40 PM
fmc400's Avatar
fmc400
MSEE
Sorry, I thought I read the word "Next?" in your post. Your steps are correct with the exception that the wire of interest is BLUE with RED stripe. Any screw that threads into unpainted metal behind the dash is fine for ground. There should be a support bracket nearby under which you can sneak a ring terminal.
In the future, when discussing electrical issues, it's in your best interest to describe any work or modifications you've done up front. That's actually true for anything, not just electrical.
Old Feb 27, 2014 | 07:45 PM
Jklnhyd's Avatar
Jklnhyd
I deleted "Next" cuz it sounded rude. Im going to get an amp and get this fixed.
Thank you FMC400, i woulda never found it because i thought i hooked that up correctly
Old Feb 27, 2014 | 08:12 PM
Jklnhyd's Avatar
Jklnhyd
Is there a reason why the dash lights are so dim?
And one bulb is out, anyone have an AutoZone number for them?😁
Old Feb 27, 2014 | 08:52 PM
fmc400's Avatar
fmc400
MSEE
There are different types of bulbs. The ones that lock into the instrument cluster are 194. The one that lights up the ***** on the left, or the heater controls are different.
Dim bulbs could be a number of things: headlight switch rheostat in poor condition, corroded connectors, etc.
Old Feb 27, 2014 | 09:21 PM
Jklnhyd's Avatar
Jklnhyd
There was a loose bulb.
And i apologize. I never thought the stereo would be the issue because i hooked it up about six months ago. The dash lights never worked, the dome light didnt work when i bought it a year ago. I ran a hot from the battery.
Old Feb 27, 2014 | 09:29 PM
fmc400's Avatar
fmc400
MSEE
Glad to hear you got it worked out.
