Newbie soon to be 59' 250 owner
How's it going everyone? New to the forum and old ford trucks, So bare with me!
I am in the process of moving into a new place and it just so happens the landlord has a 59 F250 she wants to get rid of. I went through it a bit but haven't gotten too serious. Everything seems REALLY solid. Seat has been reupholstered, engine seems to have been out, new exhaust she is the second owner and the truck seems to have been garage kept and cared for.
The only major problem on the surface is the clutch pedal has no input so the clutch isn't disengaging. I'm assuming this will be a clutch master issue. But we will see.
My biggest question is what are the differences between the f100 and f250? Is it just a matter of suspension and if so are they interchangeable? I want to lower (I know there are varying opinions on this with the old ones) the truck and keep it semi comfortable.
Ill take some pictures of her tomorrow...
Welcome to FTE.
Much of the front suspension is interchangeable. Even though changing the front end would have given me more options, i.e, disc brakes, wheels, etc., I just stayed stock.
There are a few here who can provide the info, and will, when they run across your thread. I daresay there are a few who will give you way more info than you were expecting, or wanting.......
So the front end of the 100/250 are mostly interchangeable, how about the rear? I guess a flip/springs/c notching is pretty universal. I would like to lower with springs so I don't have to cut the frame.
I don't plan on doing much to change it but I do want to lower it 2-3 inches and throw some nice wheels on it. Other than that it will be maintenance some restoration and a paint job.
I was able to snap a few terrible shots today. The truck is extremely solid...
Typical rust outs are back of front fenders and front cab corners/mounts. Are those solid? From what I see, you have about the best starting platform you can ask for.
I lowered my f100 using reverse eye leafs in the springs. Got them from Sac Vintage Ford. Right around 2 inches front and rear.
I looked quick underneath (happened to be by the rear of the cab) and the Seams were at a quick glance perfect. Are the springs different from the 100 to the 250? Two inches lower is exactly what I'm looking for....
I'm not well versed with the older trucks. I have an 85 volkswagen scirocco an fj and a 95.5 Audi wagon. I've owned A LOT of vehicles I figured I needed an American car. I was planning on a 67-69 lincoln continental. But I couldn't pass this truck up.
