272 Waterpump questions
Old 02-23-2014, 08:50 AM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Hi guys
I have been looking on the waterpump science I took it of the engine and had a few questions?
What should the clearence between the impeller wings and the pumphousing be?
What is done on a rebuild pump? bearings and seals?
How to I get the pump appart? do I press the fan flange off the shaft or whats the procedure?
I know there are new and rebuilt one, but thats on the other side of the
pond.... I wanted to try rebuild this one...
Thanks
Old 02-23-2014, 09:07 AM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
This video should help. It gave me the courage (stupidity?) to rebuild mine. Measure before disassembling and write everything down. The shop manual also has specs on engine mounting surface to pulley mounting hub distance. Measure first. Write it down.
Most kits come with a new impeller, bearing, and seal. Impeller to housing clearance is typically ~.030" but, measure and verify with the shop manual.
Old 02-23-2014, 12:01 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
That one was great! That wasnt that hard?
Anyone know the specs for the distances? My pump cant be completley accurate as the waterpump pulle is slightly offset to the motor compared to the crank. So the belt is not vertical!
Old 02-23-2014, 04:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B6C-8501-B .. Waterpump / Obsolete
1956 F100/600 272 except F600 w/272 H/D / 1957/64 F100/600 272/292 / 1962/64 C Series Tilt Cab 292.
Old 02-23-2014, 06:48 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
I can still get them through NAPA for around $60.00
Old 02-24-2014, 12:21 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Just an FYI there are two different rebuild kits, Don't ask how I know. The seals are different and you ( or at least I) can't tell until you get them apart. It's easy to get apart but to just get the seal is hard to do. I ended up getting a rebuilt pump at my local parts store but I believe rockauto has them too.
Old 02-24-2014, 12:23 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Thanks guys
I haven´t found any yet just selling the rebuild kit
Old 02-24-2014, 12:26 PM
bjmayberry2
From RockAuto's website
1956 FORD F-100 4.4L 272cid V8 :
Cooling System : Water Pump Price $58.79
AIRTEX Part # AW488 {#WP129} Includes Gasket w/5/8" Bearing Shaft
Old 02-24-2014, 12:28 PM
bjmayberry2
Old 02-24-2014, 12:29 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
I could only find the whole unit? hmmm
Old 02-24-2014, 12:34 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Why does one of them say discontinued and the other Photo comming soon? for the same partnumber??
Then on the other hand $60 isn´t that much for a rebuild pump, but I am kind of into this for the renovation part aswell, not only swapping parts....
Old 02-24-2014, 04:40 PM
bjmayberry2
Not sure about why one says discontinued unless they carried both sizes and now they don't. I got my kit from them but like I said before I didn't know there was a difference. I'd suggest pressing the pump shaft out and measuring it, then calling MACs to be sure you get the right one. The video above shows how to disassemble the pump.
Folkles
04-06-2015 04:05 PM
hotrod351
01-01-2012 08:14 PM
john smith jr
11-07-2010 03:46 PM
Fat Fendered Ford
09-25-2009 08:20 AM
sweets64f100
04-01-2005 03:10 PM
Quick Reply: 272 Waterpump questions
