"4-wheeling" a 2wd.
But you do have to be careful the momentum doesn't cause you to bounce off course and get stuck.
I used to drive my '81 Pontiac Firebird with an open diff up a muddy mountain road. Momentum was definately my friend. The tires were spinning at 70 mph while the car was moving about 8 mph. People at the top with 4x4 trucks couldn't believe it.
So, yeah, I concur that momentum is your friend. Sometimes it just gets you stuck really bad.
Momentum is based on vehicle speed, not tire speed. It will either get you through a bad place and on to somewhere you can actually drive out of, or it will get you further into a bad place so you need to be pulled farther back to get out, or it will break you. So as was said several years ago when this thread was active, you need to be very careful with the use of momentum, but sometimes it's the right way to get through a short, not-too-bad spot.
I didn't realize this thread went back to 2014.
Yes, I had lots of wheel spin, but had I lifted off of the accelerator completely, the vehicle still would have moved forward, however slight. The vehicle would not have stopped instantly, that would defy physics. What I had was barely enough traction coupled with high wheel speed to overcome the mud and gravity. Have a good week my friend.
