Injector Upgrade - time to make a decision
I've though about which injectors to put in the Excursion so much that I've reached overload and my brain can't take it anymore. I wanted to see what FTE thoughts were and if I am missing anything.
background : My F-250 has Swamps 175/146 single shot injectors/Van turbo/T. Wildman Tunes, stock HPOP & stock fuel system. It's a great setup for towing and some occasional street fun. I wouldn't change the setup at all - have been very happy with it. Sitting at 350 hp & 700TQ.
The Excursion currently has stock split shot injectors, Stock turbo with the high flow outlet, T. Wildman Tunes, stock fuel & stock HPOP. Newly built HD tranny - not a BTS but Jerry at J&M know's his stuff.
1. Even though I am happy with the setup in the F-250, I want to do something different in the Excursion. Minimum around the 400 hp mark and 425-450 on the top end would be the HP goals.
2. I don't tow much with the excursion except for the occasional flatbed trailer pull to the landfill and a boat twice a year. So, not focused on a tow setup - a daily driver.
I'm 99.9% set on the H2E Turbo. going to order Strictly Diesel's Regulated return. Either a Stealth HPOP or Bob's Adrenaline.
Injectors - I'm not towing much so I don't necessarily have to worry about EGT's in the same way when towing. For a while I was pretty much set on the 238/80 hybrids with Tony's tunes keeping it around the 450 level. But recently I have been leaning more towards the 160/100's or 160/80's for better fuel atomization and combustion efficiency compared to the Hybrids.
any thoughts or recommendations?
I'm gonna pull the trigger on ordering stuff shortley - start the install after the snow ments & I don't need to rely on the 4x4 vehicle as much.
As you know... I'm right about at your goal, but I had to add ladder bars on my stock-height truck to prevent axle-wrap when Pedal and Matt do their dance... and that's with rolling the accelerator. I had to beef up my intake significantly just to take the 38R, let alone an H2E. You will also likely want some live tuning to keep the street manners on your land yacht. The stock fuel pump will just keep up with your sticks at WOT, if you have a proper fuel delivery system and the in-tank mods. I went with the plain 'ol T500 and it doesn't strain in the least at WOT. Factor all of that into your budget when you go Stage IIs.
That being said... for just sending the pokeys to the rearview on a two-lane up a grade - you won't be able to chisel the corners of your mouth away from your ears. That grin is bone-deep.
...................... You will also likely want some live tuning to keep the street manners on your land yacht. The stock fuel pump will just keep up with your sticks at WOT, if you have a proper fuel delivery system and the in-tank mods. I went with the plain 'ol T500 and it doesn't strain in the least at WOT. Factor all of that into your budget when you go Stage IIs...................
- If I choose the 160/100's I'm approaching or at the the nozzle size that tends to need live tuning.
- If I choose the 238/80 hybrids I'm dealing with the fuel atomization and lower combustion efficiency from the lower injected fuel pressure - which I'm wondering what this will do to cold starts in South Dakota?
You know more than me, but if you go with the 160/100's you can reach your goal pretty solidly with that H2E and proper tuning, and the great thing is you can have Tony tune it and de-tune it so you can do some towing. The great things is, these guys who know what they are doing, like Tony, can dial them way back and you can pretty much do anything you want/need to do.
Yeah, the modded H2E seems to flow quite a bit more. Rocky (Rockin S) is gonna send it out to get ceramic coated as well.
This is why I'm struggling on the decision (this week ).....
But I think you touched on a very important issue that most guys don't have to deal with and that is the -20* to -30* below zero temps you see in SD. So I am glad to see that is playing a factor in your choice. Just because it might work for a guy in TX, FL, CA doesn't mean it will work for you. So it will be interesting to see if any cold weather guys running large injectors weigh in on this.
By the way nice move on the H2E !!
I don't know jack. But based on what I've read, given your goals and mods, I'd look at Mike Farmer's Sureflows. You'll find some threads on other forums. He builds 200/100s like BDK mentioned.
And thanks for the crickets, I lolled.
I wouldn't hesitate to do 160/100s with an S366 for that power level. There's nothing crazy or new about that setup. Live tuning won't be necessary. You may need a tweak or two in order to make it just how you like it, but the first set of tunes should be pretty solid, if not spot on.. That setup should put you right at 450-460hp. Another turbo that you could try out would be the S364.5 FMW. The specs look promising to me, but I haven't had the opportunity to try it out yet. Obviously the GTP38R is also an option.
238/80's with an S465 or an externally wastegated S366 would be a nice setup also. That setup will be capable of anywhere from 480-520hp though. I know there are guys farther north running big hybrids.. Dave comes to mind. He's running 400/400's in Alaska... I'm in Texas, so what do I know, but I'm going to tell you that hybrids shouldn't have an issue with your temps.
I tend not to suggest the H2E kit simply b/c of the T4i flange and because I don't like that the Hypermax kit still uses donut gaskets.
Thanks for all the input
Ed, Tony has known me & my driving habits for about 10 years so he suggested the 160/80's or the 175/80's for the 400HP level I am after. But he also said he could "tame the beast" if I wanted larger injectors so I would have room to grow down the road. I've changed my PCM to a PMT1 PCM so I should have allot of options and get around some of the Excursion quirks.
David - thanks for the link, something to check into for sure.
Travis - thanks for the additional options - you just added to my homework pile!.
According to Cary & Rocky they can get the moded H2E Turbo with bellowed up pipes and the new CAC tubes. But I'll verify that to make sure......
I've looked at this chart by Matt (Gearhead) & Bill (PHP) alot this week......a good reference for estimated HP levels when choosing injectors....
Power Hungry Performance - injector selection
