Bent axles on 2012 F-150
I bought this truck in September of 2012 and have only put about 21k miles on it. About 7 months I noticed a clicking noise while I was rolling to a stop. I took it into the dealer and they said they couldn't duplicate the noise(of course). So I left and decided to bring it back when I had time. I then was placed "on call" at work so I had no specific time to go into work and no specific days off so I was unable to schedule another appointment. Finally took it back into the dealer about 2 weeks ago and made sure they heard the noise by driving with them. Well just got back my truck earlier today and drove it for about a mile when I realized the noise was still there, or just came back. They ended up replacing both rear axles because they were bent and that was causing the noise. I haven't mentioned yet that I put a lift kit on it and bigger tires. The dealer obviously is saying the noise is because the lift kit and they cant authorize anymore work because my warranty is voided on the suspension now. Could the bending of the rear axles be caused by oversized tires and rims with possibly too much backspacing on the wheel, or just to big of a wheel and tire. Not sure if I should press this to be fixed at the dealer or try and take care of it myself. Let me know, thanks guys.
POSTED THIS IN WRONG THREAD FIRST, PLEASE DONT MARK ME AS SPAM OR SOMETHING. Not sure how to delete other one.
I know some people who have bent the Raptor axles, but they are actually a little wider than the regular F150. But the tubes were bent, and it almost sounds like you are talking the axle shafts. I have jumped and beat on my Raptor, and have not bent, even with offset wheels. If the axle shafts were what you are talking about and those were replaced, I would think maybe the axle housing is bent and caused all of the problems. As far as Ford saying the lift may have contributed to this issue, anything is possible and their right to deny warranty. But would contact the lift company and see if they can help.
Thanks for your response, let me know if you have any other ideas.
I think your dealer, and Ford, are on the right track with your oversized tires being a probable cause. Your suspension and driveline components are designed for wheels and tires of a certain size. When you put a lift kit and big tires on you are magnifying the stress on the axle, wheel bearings, and brakes. It's pretty tough to do damage to these axles, but when you modify them in a manner that exceeds factory specifications stuff can happen.
I think you're fortunate that Ford covered the repair the first time.
There are a variety of axle shaft makers, many of which advertise their shafts to be higher strength than the stock parts. Which axle is under your truck? It's either the 8.8" or 9.75". Here's a cheat sheet:
What brand lift? I think some of them come with a suspension warranty (Pro-Comp)? Don't know to what extent the warranty covers. I'm sure some of these folks that have experience in this area will know. Did you install the lift, or was it done by a 3rd party dealer/shop?
Something just doesn't sit right with me on this. I've done some searching around, and it's darn hard to find anyone who bent an axleshaft on a 9.75. I sort of assumed you had the 8.8 which has significantly thinner shafts.
How sure are you that the axleshafts are bent? Did the dealer show you?
I was thinking the exact same thing as NASSTY. Also is it the axle shafts or the axle tubes that are bent? If it's tubes that's usually a sign of being overloaded or jumping. I honestly can't see how installing a lift would cause either parts to bend. I'm thinking there is more to this story. And for the record I'm not trying to make it sound like your trying to hide anything from us. Just that I thought you said you bought this used. I'm thinking maybe to po did something that caused this issue. Then tried to get it fixed under warranty. The claim denied so he then traded it in, you know to pass the buck so to speak.
Eh, I don't think so. The weight of the wheels should have nothing to do with a clicking noise. After all, a ~75-100 lb tire and wheel is NOTHING compared to the 4,000 lbs of weight the axle is rated for.
With your big wheels on the truck spin them slowly taking a good look on the inside and outside of the rim. If the axle shaft is bent it'll wobble in and out as it rotates.
