First diesel!
Old Feb 20, 2014 | 08:44 PM
Tyler.172's Avatar
Tyler.172
Originally Posted by ATS Junior
Congratulations on the new truck! What type of springs are you looking for? Just standard duty replacements?
If i end up having to replace springs im gunna go with rough country 4in lift leafs cuz my truck has a 4in lift
Old Feb 20, 2014 | 08:47 PM
Tyler.172's Avatar
Tyler.172
Originally Posted by oldbird1965
Welcome and looks like a nice truck. What are you taking up at school?
Well im certified in suzuki and yamaha right now just finishing up honda im training to be a motorcycle tech, but im trained to work on all of yamaha and suzuki motor products, the longer im here the more i dislike 2 things, hondas and phoenix arizona
Old Feb 20, 2014 | 08:49 PM
Tyler.172's Avatar
Tyler.172
Is there a way i can check the pivot bushing to confirm its bad? I dont want to have to buy new springs if i dont have to cuz theres other things id like to fix as well
Old Feb 20, 2014 | 08:53 PM
ReBilld's Avatar
ReBilld
You can get under there and look at them. See if you can tell if the inner sleeve is squished up toward the top of the rubber bushing. You can try moving them with a pry bar or jack also.
Old Feb 20, 2014 | 09:26 PM
Tyler.172's Avatar
Tyler.172
Ok so essentially if its not centered its bad? As well as if i can move the beam?
Old Feb 20, 2014 | 09:37 PM
ReBilld's Avatar
ReBilld
The beam will move a little. The bushings are rubber. If they move a lot and you can see the inner sleeve moving in the rubber, then they should be replaced.
Old Feb 20, 2014 | 09:42 PM
Tyler.172's Avatar
Tyler.172
Ok thanks ill look at it tomorrow afternoon and let you know what i find!
Old Feb 20, 2014 | 09:44 PM
ReBilld's Avatar
ReBilld
Good luck bud. I hope they are OK
Old Feb 21, 2014 | 12:58 AM
Tyler.172's Avatar
Tyler.172
Same here! Thanks! just so I can check everything right away ill describe the problems im having and maybe you guys can tell me anything else to look at, the truck leans down to the right, in the front. the tires are pretty straight when I pull into a parking spot and stop, but if I back in to a spot it leans really bad and the passanger tire gets negative camber
Old Feb 21, 2014 | 06:56 PM
Tyler.172's Avatar
Tyler.172
Looked at the bushings and im gunna go with replace them, the one looks like the bolt sits way high up in the bushing like its pinched almost
Old Feb 21, 2014 | 08:28 PM
ReBilld's Avatar
ReBilld
Replace them with poly bushings. Do your spring bushings with poly too. Makes a world of difference!
Old Feb 21, 2014 | 09:45 PM
Tyler.172's Avatar
Tyler.172
Thats the plan! Hopefully the axle pivot bushings are the last thing ill have to replace for now and hopefully thatll fix my lean! Do i need a press for this job? Weve got plasma cutter drills and cut off wheels lol
Old Feb 22, 2014 | 01:55 PM
  #28
Tyler.172's Avatar
Tyler.172
Well bought the bushings now just gotta install them, im about ready to drive the truck through the dealership wall tho they said they fixed the oil leak, yea bull its leaking again
Old Feb 22, 2014 | 06:09 PM
  #29
stainlessstroker95's Avatar
stainlessstroker95
Where is it leaking?
Old Feb 22, 2014 | 08:35 PM
  #30
mojoman's Avatar
mojoman
work on it yourself and know what you did...or pay someone else and hope they did what you wanted...read/search here and you will rarely need a mechanic..hth
mojo never put my vehicles thru the stress of another pair of hands handlin' them...
