My 1958 F-100 Restore Project
Hi guys,
New to the forum, just purchased a 1958 Ford F-100 over the weekend. I have been browsing for a long time and finally settled on one.
I am looking to do a full restore, and i'm bracing myself for what lies ahead.
Don't know much about the truck, bought it off a mechanic who only bought it for the bed. He gave me the registration card from the previous owner, last registration shows 1992 in Beaumont, CA.
VIN: F10J8L11629
BODY TYPE MODEL: ZH58TINS
I have it out on the street in front of my house right now. I have a garage but its only about 18x8, so the truck will fit once I get it running, just won't leave much room to work around it (driveway is on an incline and truck is too heavy to push in). Over the weekend I pulled the bench seat and fuel tank. Nastiest gas I have ever smelled or laid my eyes on. Do you recommend cleaning the tank or purchasing a new one? Also the fuel lines were clogged with what looked like RTV sealant, i'm guessing it's just gunk from sitting for so many years?? Im all for doing a lot of the work myself, just need to browse this forum for more tips.
Gonna be a fun adventure and I hope to post updates as often as possible. Any tips or encouragement is greatly appreciated. Take a look at the pics in my album and tell me what ya think!
VIN: F10J8L11629
I am sort of at the same place you are. I used a glass jar and a short tube with a filter until I rebuilt the carb and had it running. I will clean the tank the best I can and put a filter before the pump until I finish several other projects on the truck. After I have it painted I will then make more improvements on my truck. Sometimes it is better to hurry up and wait. If you are just going to drive it then you should spend more time on the small stuff.
good luck
good luck
Thanks for the tips guys! Ill be diving in a little deeper tomorrow and trying to clean out the fuel tank. I took off the radiator and hoses last night. Peeked in with a flashlight into the water pump and saw nothing but gunk. Im gonna post pics tomorrow, my pics from last night in the dark aren't the best.
good luck
good luck
Also make sure you remove anything attached to the tank and seal the holes up with some aluminum tape or equivalent. Haven't used gorilla tape, but it may suffice.
Getting rocks or whatever you use isn't that difficult if you first take teh tank out. Get some methyl ethyl ketone (MEK). I prefer to use 3/8" nuts as the abrasive. Just count the # you use before putting them in. You can basically use anything. If you have a "20 year box" of hardware, use that. I like using the Kreem gas tank liner. I've done many motorcycle gas tanks with it and it works well.
Had not thought about the nuts. I will just use small gravel then diesel. I also will put a inline filter between the tank and fuel pump. I looked into the coating products but heard that sometimes they will flake after awhile. Will start this weekend. I will not count, just listen for the rattle.
ec
ec
ec
ec
