Finally a Victory Gauges working!
You all know how much "whining" I done over these gauges not working, All 3 dead.
Checked wiring. Good
ICVR. Good pulsing
Gauges them selves bench tested with gas sender.. good, all working.
Put it all back together....Gauges dead!
Remove and test Ignition switch. Good. Put back together....Dead....
Tear off the instrument cluster again, trace the Printed board around all the way to the Tach. Found it! PCB wear mark through the power line!
Solder in a patch. putting it back together now.........
ICVR. Good pulsing
bcamill
12-10-2018 05:08 PM
xc4jokestomper
05-26-2011 06:12 AM
