Question for dark siders
I have checked all the vacuum lines and they are ok. I rechecked pump pressure and it is around 8 1/2 psi. I did notice it was wet around the accelerator pump gasket. I think it is starving for gas. I start it up and it will run fine for a few minutes then it will start to run rough then die. I am thinking I need to pull the carb off and pull the front bowl off. I think there is a needle or float problem.
I removed the carb and have removed the front bowl. I do not seen anything that looks wrong. I tighten the screws down some more on the accelerator pump housing. Is there any measurement to check the float setting? How do you check to see if the float is damaged or not? It is the plastic kind.
I'm not sure that it makes a difference as long as the flow is correct. Most that I have seen are between the pump and the carb. That is not stock as they relied on the fuel bowl on the pump for separation of water and dirt.
To check for a damaged float, remove the float(usually by pushing a "nail" (due to the fact they often have a head on one end) out of it's hinge. Look for cracks or fuel leaking out of the float. Shake float to feel/hear fuel inside of float. Submerse float in water to see if any air escapes from it.
You never did answer if there was black smoke coming from the tail pipe? You can also pull a plug to see if it's wet from gas to determine if it's running way too rich.
Is the idle screw turned in enough? Is the idle mixture screw set correctly?
PS -- on this style Holley, I don't think there are float measurements at all; as shown in the video in #12, you set it with the engine running.
#29
That's a good point. It's possible to have the throttle plates completely closed and make up for it with the idle screws. That won't be consistent or work well. Make sure the blades are open a little and set the mix screws. If you have too much timing, it can also raise the idle to where the blades are completely shut.
The picture is of the bottom of my carb (not a 4160 but the principle is the same). If there is or was any signs of dirt I would recommend getting a can of carb cleaner, one with the plastic straw on the end, and spray through all the ports and passages in the carb. This means taking it off and apart again but it sounds like it is clear after you disassemble it and runs OK then dirt is re-clogging the passageways in the carb and/or the fuel filter after it runs for 3-4 days. Obviously concentrate on the front primary circuits. I would even remove the idle adjustment screws and spray cleaner through them until it comes out of the idle ports in the throttle bores. You may also need another new filter. Before doing that remove the sending unit and check the bottom of the tank, or you can drain the tank but when you do use a paper coffee filter in the funnel to see what kind of dirt comes out. If it is a lot you may have to take the tank out and have it flushed clean at a radiator shop.
#30
So I rebuilt the carb. Still not sure what model I have. It has a number on the front of the bowl of 80457-2 3171. On top of the bowl is R7809. I have been told the power valve has blown(I knew there was reason for my dislike of Holley carbs). I bought one at O'Reilly's which was a 3.5. Was not sure what was in it. When I pulled the fuel bowl off I found it has a 6.5. I did not keep the old one and did not think to look at it. My problem is since I don't know if I bought the right rebuild kit, I don't know which size is the right one.
