Clutch F250 91' 4x4
I would get a Haynes repair manual that covers your model truck. The Haynes manual gives a good step by step of what's involved. You will get a good idea of what's involved.
You will need a fair selection of both fractional and metric hand tools. You will need a transmission jack, nothing fancy just functional, you may be able to rent one.
Depending on which engine you have, you may have an internal slave cylinder. The 300, 302, and 351 have an internal slave cylinder. The 460 and the diesel have an external slave cylinder. If you have an internal slave cylinder, use only a genuine Ford replacement slave cylinder. Personally I would get all the parts from Ford.
I have used luk, and centerforce aftermarket kits before and have been very happy with both and most of them come with an alignment tool which is nice
its pretty straight forward,
drain the trans and transfer case (if your 4x4)
drop both drive shafts
undo the linkages and pull the shifter out of its position
un bolt the slave cylinder, or un doo the hydraulic lines
pull the transfer case if you have a jack pull them together and save some work
pull the trans
unbolt the pressure plate and the disk comes out with it
install is the reverse
when your doing the clutch look for glazing on the flywheel, leaking rear main seals.
always replace the throwout bearing, and the slave cylinder if its internal as cheap insurance.
its a day and a half job for one person, half day if you have a friend to help you wrestle the trans and transfercase in.
pull the trans
pull the trans
pull the trans
Maybe Im thinking about this wrong?
It's just not easy..have to jack the front of the trans up, slide the clutch onto the input shaft to get the motor back while dealing with motor mount studs that only line up when the engine is back far enough, and making sure the splines of the transmission line up with the clutch disk, wires and vacum hoses all over the place
I've done it in a 2.9 Bronco II and there was a lot of manhandling, somebody under the truck working the trans while someone up to is working the engine.
mustangsallysdad
08-26-2012 03:41 PM
colesdad
05-03-2010 09:24 PM
Bullride_101
1983 - 2012 Ranger & B-Series
02-03-2009 12:47 PM
1982fordf100
01-25-2004 12:58 AM
bob the viking
01-23-2003 11:29 PM
