Mirrors, grilles, and headlights for '02 SD
I have a 2002 F-250 Super Duty Crew Cab 4WD XLT. It has the smaller mirrors, not the nice big tow mirrors. If I buy the big tow mirrors, how hard are they to change out? Will the power mirror plug from my small mirrors just plug right into the bigger mirrors, etc? Also what years of mirrors will fit cleanly right on to my '02. If newer models mirrors will fit might be a nice more modern look. Also will the grille and or headlights from any newer generation super dutys fir on to the '02? could be a cheap way to give old silver a little modern face lift. Thanks guys.
Any of the mirrors from the newer super duty's will fit your truck. I think the wiring is pretty simple on them. And you might already have all the wires needed on your truck, just not in use. But I'm not 100% sure on that though, so hopefully somebody that has more knowledge will chime in here soon. I know they will fit, but I'm just not sure on the wiring, either way its a pretty simple install for the most part.
If you want the 08+ ones a lot of people use these. I have the basic tow mirrors without the lights on my 02 now, and wanted to upgrade eventually. I originally wanted the 04-07 ones with the clearance lights, but after seeing a few members on here put the 08+ ones on our model year trucks, I think they look pretty good.
The only difference is the mirror caps between these two.
2003 Ford F250 Truck Power Heated Light Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com
2003 Ford F250 Truck Power Heated Signal & Clearance Light Telescoping Upgrade Mirror Pair at 1AAuto.com
For the grille only the 05-07 ones will fit, any newer will not, other than that you will have to go with something aftermarket. The 05-07 one will have to be cut to fit, you can either buy it already cut or cut it your self. Just the bottom needs to be trimmed.
I have one on mine, it was on the truck when I bought it, I think it looks pretty good.
Compared to my Dads 06.
The 05-07 headlights will fit with some trimming and cutting. I've seen it done before. I think you could also change the header panel, but I'm not for sure on that. Or you could go with aftermarket headlights. I'm going to get some aftermarket projector halo headlights for mine eventually, but I'm not sure if you are into that look or not.
Hope this helps.
Hope this helps.
on
Here is our 02 F250 crew with a 05 XL grille and bumper but keeping the 02 headlights and license plate bracket(I sorta like this look)
you can also compare mine to Red devils truck to see which one you prefer (you can use any 05-07 grille just ours is the XL grille)
Hope this helps.
Hope this helps.
Trav
those are all things I`m looking to change out on my 99 if I end up keeping it.....even been trying to find a way to make an 08 style grille work with out changing entire front end (I know, I know) but have a few ideas similar to the trimmed 05-07 grilles you can buy, wouldn't be an exact stock appearance but at this point stock is not a factor
robinsonpowerstroke
27
12-13-2009 11:01 PM
