Vibration on low gears
Old 02-04-2014, 06:48 PM
mtorres555's Avatar
mtorres555
mtorres555 is offline
I have a 2000 Ford F-150 with approx. 214,000 miles on it. Recently, I've noticed that it vibrates at very low idling and start-up speeds. Can someone please give me some (hopefully less expensive) issues to look into?
Old 02-07-2014, 01:54 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Welcome to the forum.
I would start with the easy stuff like how old are the plugs? MAF clean?
Old 02-07-2014, 03:30 PM
mtorres555's Avatar
mtorres555
Thanks for your response LxMan1! I recently had a tune up done a few months ago, so the plugs should be good. In reviewing my paperwork from the shop at the time of the tune-up, they noted that there was a mis-fire on #2 at that point. I wonder if there is something wrong with the housing assembly.
Old 02-21-2014, 06:09 PM
orbust's Avatar
orbust
orbust is offline
I would start by checking the plugs and coils. When a coil or two goes bad it can cause a serious vibration that is typically felt at low loads such as cruising at freeway speeds. I have seen a truck with two bad coils feel like it was going to rattle itself apart at cruising speeds. I have heard people incorrectly diagnose this as water in the fuel tank. After that I would probably move toward the rear diff and the tranny and drivetrain components such as u joints.
Old 02-21-2014, 06:49 PM
mtorres555's Avatar
mtorres555
Orbust, thank you for responding to my inquiry! Although I've taken my truck in for a reading of the codes on the CHECK ENGINE LIGHT, they never mentioned anything about the coils. I'm gonna take it in and ask the shop to specifically look at the coils.
Old 02-21-2014, 08:37 PM
orbust's Avatar
orbust
orbust is offline
NP, Also... might want to have them check torque converter as well. Another possibility when it comes to low load vibration.
DanielT28
01-31-2015 07:20 AM
stydel311
02-17-2014 04:00 PM
speedworks
01-05-2008 08:45 PM
BigDa
1997 - 2003 F150
05-06-2007 11:06 AM
djexplor
11-26-2005 01:14 AM
Quick Reply: Vibration on low gears
