Can anyone confirm that p/n 4C3Z9D930AA is the correct fuel injection harness for my 04 EX (vin: 1FMSU45P54ED76417)? Mine is a chafe-o-matic and I've had it with band-aiding it. My original harness tag says 264B1844137 C95. Thanks in advance.
The harness tag is International number
First number is FORD second is International and its probably been updated so that might be why your C95 is Now C97
4C3Z 9D930 AA / 1844137C97-------------------------------------Injector Wiring Harness (2004)*
Thanks Brother! I ended up pulling my harness and found more chafing in addition to the ones I repaired a year ago. I'm hoping that's what was causing the 4 injector circuit high codes.
The best thing to do is give the IH number to the Ford parts guy and let him get the right one for your truck OR get him to give you the correct part number and get it from Auto Nation White Bear Lake.
I sent an email to Auto Nation last night with the VIN and IH #. I'll give them a call Monday morning to confirm it's the one Blade mentioned.
