Leaking Radiator - Near Lower Hose
Old 02-17-2014, 06:39 PM
EtzCutter7's Avatar
EtzCutter7
EtzCutter7 is offline
A little background on the truck, purchased used with 223,000 miles. I've had the truck for about three months. I did a coolant flush with distilled water and VC-9 a month ago. I can't say that I've watched this area since owning the truck. After doing the flush I have been watching this area.
When I look at the radiator from the front, from the top, I do not see any leaks. When I look at the radiator from the engine side, from the top, I do not see any leaks. Is the bottom flange of the radiator leaking? Is this fluid coming from radiator? Is this a typical leak location for the OEM plastic radiator?
Is this, gulp, a symptom of something else? Is my truck okay?
Old 02-17-2014, 06:49 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Looks like you sprung a leak around the crimp for sure. With the miles and unknown, I would replace.
Old 02-17-2014, 07:15 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
If the tank's not cracked a good radiator shop can reseal them, but those aluminum tabs tend to stress crack. OEM radiators aren't that expensive, and as John said, with that many miles you'll be better off to replace it. They are known to leak around the tank seam.
Old 02-17-2014, 07:21 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Radiator depot has them for 200 bucks with lifetime warranty
Old 02-17-2014, 10:19 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
But where do they come from? China maybe?
Then there is Aluminum Radiator, Performance Radiator, Cooling Products - Mishimoto Automotive
They are on the other end of the price spectrum.
Sean
Old 02-17-2014, 10:41 PM
EtzCutter7's Avatar
EtzCutter7
There's trusty Ford OEM...
There's Mishimoto aluminum radiators...
There's Bullet Proof Diesel Aluminum radiators...
Personal testimonies about each one that you can share?
Old 02-17-2014, 10:47 PM
9228.bobcat
Guess it depends on how much you want to spend. I've used radiator depots radiators for years and never had a problem with them. But in saying that I normally dont keep a truck longer than 6 months so thats about all I can say about that. As for trusty fords, never bought one. All I know is ford didnt do that great with radiators for the 6.4 and 6.7's. I kinda had to throw that in.lol
BigBlue2
10-23-2016 08:22 PM
rebelmdb
17
09-07-2010 12:25 PM
FordLou
1997 - 2003 F150
07-06-2010 05:55 PM
tenptbuck7mmmag
02-12-2006 10:16 AM
Simek
08-24-2004 01:10 PM
Quick Reply: Leaking Radiator - Near Lower Hose
