54 Front axle
Old Feb 12, 2014 | 03:18 PM
Customcab's Avatar
Customcab
54 Front axle
Got a opporunity to purchase a set of nice wheels and tires along with a 54 F100 front straight axle; the bolt pattern on the axle is 5 on 4 1/2 Discs; I wondering if the axle is the same with as a 62 F100 project I'm going to build this summer? I heading out to measure the front axle under my 62 truck; I'll be measureing from outer leaf to outer leaf. Can anyone confirm distance on a 54 model. I assume a 51-56 might be the same and then 57-60, might be same as 61-64.
Thanks
Old Feb 12, 2014 | 04:51 PM
teardropty's Avatar
teardropty
For starters the bolt pattern you stated (5 x 4.5) is not correct for a 54 axle. Should be 5 X5.5 if original. Sounds like someone swapped it out to discs. Not a big deal but make sure the axle is truly a 54. Can't tell you about the distance, etc. as my trucks are asleep for the winter. Make sure you measure spring pad to spring pad, not leaf to leaf.
Old Feb 13, 2014 | 08:57 AM
Customcab's Avatar
Customcab
Thanks Teardropty;
I didn't think about lenght verse width; I was able to measure my 62 and a 52 F100 yesterday; the width from leaf to leaf was (34 1/4") for 62 model and (30 3/4") I beleive for the 52 model. And yes the guy did a disc conversion on his 64 to allow athat bolt pattern. I also measured the bolts holding the spindles on each (don't know the proper name) and there's about a (1 1/4") difference there as well. I guess the only other option is purchasing the tire combo from him and buying a Speedway disc kit. And I might still purchase his axle setup for a future sell or build.
Also like your Avatar; its very personnel to me as well to "Never Forget", Currently a Professional Fire Fighter and prior to that spent 20yrs in US ARMY ;an the last unit I was in my Commander was murder at the Petagon. Left behind a wife and young son.
shadowwalker
Jan 1, 2006 01:58 PM
jack71
Aug 20, 2005 05:28 PM
trav54
Oct 21, 2004 09:33 AM
Grumpy Gramps
Aug 13, 2004 05:21 PM
wheelie
Nov 24, 2002 11:13 PM
