6.7 hot engine oil???
#46
#47
#48
#49
#51
Scott - what oil were/are you using? Your long trip in some ways is similar to what we are doing though aren't doing the Rockies but the Wasach and Sangre de Cristos with a 77500 mile truck and 4500 miles so far on this trip since 17 August with another 3-4000 to go. I may send a sample of the Motorcraft 15W40 off to Blackstone for that late line in the sand on to be an 80K+ engine
#53
Just the motorcraft 15-40Wt oil. Same oil I used in my 6.4 and it always held up good on the 5K oil change intervals I run.
I do think it would go the 3--4k more you have for your trip though.
Running my Monarch pass and on I 70 thru the eishhower tunnel and several other long grades is a heck of a workout. Especially when you have your foot thru the floor.
#54
That Colorado portion of I-70 can be a challenge though I do believe that Utah has some l-o-o-o-g 6-7% grades that are about as bad. We were able to 'blow' past lesser RV combos with ease. The last time I did the CO portion pf the route was in a foreign made underpowered rent-a-clunk on a ski trip though I did run my ancient 460 F350 with a 30' fiver along the route as well many years back.
#55
Rotella T6 5W40. Runs around town 198-203, highway speeds 203-210, with the camper normal driving 210-215, long grades with camper 230-245. This doesn't bother me a bit because when it runs up this high it goes back down to normal operating temps in a matter of just minutes, the cooling system is truly amazing. Not to mention no regens when running hard.
#56
Received 3,988 Likes
on
Reading the Diesel supplement book that came with the truck......for the cold winters and the hot summer pulling heavy (18K lbs) loads....the book lead me to use the 5W-40 synthetic. I'm sure, there is no one answer. my next choice would be the 15W-40 in the summer months and the 10W-30 in the winter......
#57
That is what I use.......
#58
I'm with you Roy, the T6 5w40 fits all the conditions I run in and it's a little bit less expensive than the motorcraft. I tow 99% of my miles and change the oil when the truck tells me to. I think the 15-40 would be my next preference but honestly I don't see how it would really matter that much. I'm trying to get the best mpg I can and the lowest cost per mile I can, within reason.
I've never been able to get the oil above 242° I think, and I've tried.
#60
