5.4L super hard to start
Old 01-30-2014, 04:35 PM
thosfsull's Avatar
thosfsull
thosfsull is offline
In an Econoline from 2002 with 158k on it. Battery clicks over and really wants to start, but seems like it gets no fuel. Usually takes a second to fourth start first thing to turn over in the morning. Yesterday at the DMV I could not get it restarted at all. Towed out of the parking lot.
recharged the battery overnight. Only started on the second try. Any ideas? This is a work truck. So i can't afford problems.
Old 01-30-2014, 04:49 PM
thosfsull's Avatar
thosfsull
I forgot to say that I had replaced the fuel filter underneath driver's door in the last 60 days too.
Old 01-30-2014, 04:54 PM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
So, it cranks and doesn't fire? Have you scanned for set or pending error codes?
It could be a number of things, but I would start by checking your fuel pressure, and maybe cleaning/inspecting your IAC.
Also, check the vacuum hoses and fittings for leaks or tears.
Old 01-30-2014, 05:49 PM
ashleyroachclip's Avatar
ashleyroachclip
ashleyroachclip is offline
The largest number of these no start , or hard start threads, are fuel related.
I don't know why the easiest test is the last one done .
Oh well .
Old 01-30-2014, 11:44 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
What should fuel rail pressure be at for a 3v 5.4 anyway???
Old 02-01-2014, 12:59 PM
thosfsull's Avatar
thosfsull
Ran a snapon scanner on tuck last night. No codes present or hidden in history.
Where are all the good can't start threads? I am on a limited basis with a computer downstairs. I found out yesterday after 10 days waiting for an MRI that I have a left lateral tibula plateau fracture from slipping but not falling on the ice in my driveway 13 days back.
Old 02-10-2014, 09:07 PM
thosfsull's Avatar
thosfsull
Let it run with keys in it locked. Turned it off out of instinct and could get it to restart immediately. Same deal today, ran nonstop for 90 minutes, got home turned off and after 30 seconds wouldn't start back like no fuel.
Old 02-13-2014, 02:00 PM
thosfsull's Avatar
thosfsull
Started up to move it up on the sidewalk for plowing last night, will see what happens now with it.
Old 02-13-2014, 07:51 PM
ashleyroachclip
Off the top of my head , fuel pressure should be around 35 or 40 psi at an idle .
This is standard for all fuel injected fords , no matter what engine you have , diesel I don't know , may be different .
When the engine doesn't start , press the Shrader valve, on the fuel rail , you should have a generous amount of fuel spraying out , not a dribble .
Old 02-13-2014, 09:32 PM
thosfsull's Avatar
thosfsull
Since it is a van, will I have to take the doghouse off in the cab to get to it? I only ask as I am on crutches with a broken leg. I try to be on it the least I can.
Especially how I would have to lie in the cab to see it if it is not accessible from the hood.
Old 02-14-2014, 08:39 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
The FP test port is definitely under the dog house, left side near the back of the rail.
mark227
1999 to 2016 Super Duty
20
12-16-2016 12:17 PM
jspence105
22
02-02-2016 02:17 PM
f250d4x4
1997 - 2003 F150
18
07-09-2015 12:02 PM
First Time Diesel
11-23-2014 07:17 AM
mustangmatt
10-06-2011 02:57 PM
Quick Reply: 5.4L super hard to start
