6.0/SCII gurus ?
Below are SCII readings at idle, unless noted otherwise. Let me know where you may see a problem or out of range readings and any recommendations.
The deltas between EOT/ECT are usually between 4 - 5 at startup & operating temps. Cold start (5* F) today showed a delta of 8 for about 2 mins, then 4 all the way through an hour drive @ 65.
1. ICP - 590 @ idle; 660 @ 1000 rpm; 840 @ 1500 rpm; 1060 @ 2000 rpm
2. MFD - 9.6
3. VFD - 11.5 - 12
4. EBP - 17.2
5. MAT - -40* ?? rechecked the pid settings from linear logic sheet for 6.0, input was correct. bad sensor? where & what to replace or check?
6. FMP - 47 - 47.5
7. FLP - 13.5 - 14
8. IPR - 23.81; 37.1@2000rpm
9. EVM - no reading; rechecked pid settings, input was correct. what to check or replace?
10. EVD - 16
11. ETP - 3
12. CVI - 4.98
13. IA1 - 6656 rechecked pid settings, input was correct, what to check or replace?
14. IA2 - 88
15. VGT - 85
Any and all diagnosis, advice & direction will be greatly appreciated!!
2. MFD - 9.6
3. VFD - 11.5 - 12
4. EBP - 17.2
6. FMP - 47 - 47.5
7. FLP - 13.5 - 14
10. EVD - 16
11. ETP - 3
12. CVI - 4.98
14. IA2 - 88
15. VGT - 85
2. MFD - 9.6
3. VFD - 11.5 - 12
4. EBP - 17.2
6. FMP - 47 - 47.5
7. FLP - 13.5 - 14
10. EVD - 16
11. ETP - 3
12. CVI - 4.98
14. IA2 - 88
15. VGT - 85
As for the EGR PIDs, my 04 wouldn't pick them up.
The VGT looks like mine. Do you have an after market exhaust? CAT still on?
The others look fine
