94 351w 5.8 Weird No Start HELP
This is thought...May have spark, but a weak spark.Coil may not be able to deliver voltage to fire. I had a similar problem and coil was worthless when cold. Tried hairdryer and it would fire over. I had a MSD coil and only lasted 6 months. 20 year old Motorcraft coil fired it right over.
Try pulling SPOUT and try cranking it over and see if it fires.
Just a couple of ideas...
If it fires without SPOUT jumper, my guess is PIP/Stator is bad.
The PIP/stator is used whether or not the SPOUT plug is in. Pulling the SPOUT out will only take part of the computer out of the equation.
You need to determine if the issue is spark or fuel. Pour a little gas into the intake when cranking, if it fires then you know you are missing fuel from the injectors. Not sure how you determined they were firing. If it does not fire up for a few seconds then you need to look at the ignition.
As previously mentioned, what color is the spark? Anything less than blue/purple means you have a weak spark that may not be strong enough to operate the engine.
Are you using a lamp type tester , or a jump gap tester ? I have seen the lamp testers give bad results .
im leaning towards ecm because the problem occurred after a hard freeze and im getting a code 10 154 and none of those are diagnostic codes by both jumping the self test and with a code reader. talked to the po today and he said he did a motor swap to the Windsor and left the 302 ecm in. I know you are about to crucify me by saying that it was running prior so not the ecm but it could have been coming and the hard freeze forced moisture into the weathergaurd and shorted out a ground or something the only reason I haven't pulled it yet is because I want to troubleshoot it down to being at least 99 percent sure its the ecm before I tear it up :beersip
