& the list gets longer : )
I've got rack & pinion power steering.
The seat is too far forward & the seat back sits up too straight for my comfort.
If I get a low back seat I can get a couple inches further back or I can tilt the seat back at a more comfortable angle.
The flat wheel could help some, but since I need to build a frame anyway.....might as well do what I want while I'm in there
That is why all pickups built since then have high back seats and extra space behind the seat back (larger cabs).
I have a pair of 1966 leather T-bird seats that I plan to use. As I have a 1950 with the smaller rear window I will put a matching pad on the back of the cab at head level too.
When I owned my harley no one saw me & I was constantly trying to avoid getting hit. CONSTANTLY.
On the other hand EVERYONE sees this truck! That won't prevent an accident. But I feel much safer in my truck than I did on my bike.
I like your idea of a brace or rack of some kind behind the low back seats.
On another note....my linear actuator & mounts are in the mail & should be home pretty quick.
Depending on how many other things I have going on I could get started soon on the automatic tilt nose
I've mentioned it before but to repeat For bucket seats that give the most room possible, are comfortable, good lumbar padding, hold you firmly, are fairly plentiful and inexpensive, try a set from a Mazda Miata. They use a formed metal shell like a bomber seat rather than a tubular frame with molded engineered foam padding instead of springs. From 90 -99 they used a low back design, Beginning in 2000, they went to government mandated integral raised backs/headrest. They can be found with a dark grey cloth or a black or tan leather upholstery (hint: the cloth upholstery is thinner) The back angle is adjustable and the backs fold forwards as well. The Miata is very popular for use in racing, so they pull the OEM seats out.
If they are seat belts linear actuators they normally only protect impact from the front and not much from the rear.
I have the controller & just received the actuator & brackets today! Can't wait!
try a set from a Mazda Miata. They use a formed metal shell like a bomber seat rather than a tubular frame with molded engineered foam padding instead of springs. From 90 -99 they used a[BOLD] low back design[/BOLD], Beginning in 2000, they went to government mandated integral raised backs/headrest.
The PO had a bench seat the was pretty big. When I got the truck I had to move the mounts back to get a couple of inches more leg room.
I ended up taking out the bench and added buckets from a 2006 VW Jetta. The overall seat is smaller and I have much more leg room. (The console is not really installed yet - its from a 2007 Ford Edge). I also shortened the column drop by 1" to move the steering wheel up.
Drive a Miata for an hour or so and you'll learn to appreciate the seats.
Grape Nehi
16
03-24-2017 07:22 AM
xplodn
38
01-19-2015 09:47 PM
muddyford75
15
11-17-2004 10:48 PM
Gwilkrrs
11-17-2002 07:58 AM
