Headers
Old Feb 3, 2014 | 08:51 AM
jammeyer's Avatar
jammeyer
Headers
I have a 1970 f100 2wd with a 425 horse 306. I was wondering if there were any other options for headers other than Hedman, Hooker, or Flowtech. If anyone could help me out it would be very appreciated. Also out of the 3 brands mentioned above what would be the best one. (I know Hooker and Flowtech are the same company but jw which is better)
thanks
josh
Old Feb 3, 2014 | 09:09 AM
lee's Avatar
lee
Hi Josh,
IMHO there all 'bout the same..... unless you go with some Sanderson shorties or tri-Y's.
If you go with the popular long tube style, I recommend you either heat rap the pipes or insulate the Starter, or both. I would go through a Starter every other year due to the header heat cooking it. Since I wrapped it in hi temp insulation it's lasted the past 5 years.
Old Feb 3, 2014 | 09:16 AM
lee's Avatar
lee
Josh, ..... just remembered something else.
I had nothing but trouble with the standard style exhaust manifold gaskets and my headers. They would eventually leak every year or two.
I recommend you use the thick solid copper gaskets. Since I went to these I have not had any leaks. Also, they are re-usable.
Old Feb 3, 2014 | 09:43 AM
jammeyer's Avatar
jammeyer
thanks lee that is some really good advice. ill have to remember that. which 1 has the thickest flange out of them?
Old Feb 3, 2014 | 12:31 PM
JEFFFAFA's Avatar
JEFFFAFA
I have a used set of long tubes I removed from my 71 F100,302, 4X2 parts truck. I don't know how much freight would be from Az. to Mo. If you're interested PM me.
Old Feb 3, 2014 | 01:02 PM
hivoltj's Avatar
hivoltj
If your 306 is in fact pushing 425 HP you're gonna need bigger headers than what will be offered for the truck application.
I had good luck running MAC TFA-693 Mustang headers in my '94 Lightning and I believe frame width is the same so with some work they should fit. They are 1-3/4" primary
justforkicks
Jun 19, 2011 01:52 AM
64F-100
13
Oct 22, 2010 12:14 PM
ray_bone40
Nov 17, 2003 03:57 AM
F250Dave
Apr 22, 2003 06:16 PM
tomw
Jul 12, 2002 09:45 PM
