NEED(want) MORE POWER!! Next level budget power thread
So, I have come to the realization that my 2001 4x4 econoline with no chip/tuner can wax the behind of my 1997 F350 in the power department. I have a strict budget of $1500 and I am hard pressed to find power for that price.. bigger injectors will require so many supporting mods that they are out of the question budget wise(at least I think they are). So my purpose of the thread is to give myself and others on a budget power quest some ideas/direction. Of course it would be nice to wax a 6.0 from light to light but I didn't buy my 7.3 for speed... I just have grown to want speed
lets set the budget at $1500-2000(max) and this must cover all necessary supporting mods
AND, lets assume that the truck already has intake, DP, exhaust, gauges... as many do including mine.
Thanks! Let the advice roll!
If it were me, I'd send the injectors to Jim and do a budget build set of stage 1s. If the injectors have lowish miles, run good, and have been well maintained then you should be able to get by with the stock P&B assemblies in your injectors. If he gets in there and it needs new P&B assemblies it will cost you another $350 and if they need new nozzles it will cost you another $400ish. Have $1300 in your pocket when you send the injectors out. If he can use the stock nozzles and P&Bs you'll get off nice and cheap.
Depending on what the injectors need is how I would decide what to do next. If the injectors don't need much, you'll be able to afford a T500 and a chip. If they need a total overhaul, just get a chip and roll with the stock HPOP until you can afford a T500.
That is if you think your trans can handle 300-350hp... If not, I'd get a chip and dump whatever else you could into the trans.
I wouldn't go above a stage 1 without e fuel. A DIY e fuel can be done around $350.
From what I understand at this level....Terminator Engineering is the way to go.....regardless of the Injector flow...he can accomodate you ...within reason.....You send him your pump OR one like it and he sends it back to you...No interchange bullchit...just take it out .....and put it in.....No head trips....
I'm pushing my 180/80's with the SD 17. It drops a little pressure when you're really pushing it, but not noticeable. Since I don't have a turbo that can handle the fuel, they're not being used to their full potential anyway.
I ran mine on stock fuel for a while as well. I know some guys get itchy about it though. I just hate that damn fuel bowl!
Tatsch....you hate the stock system because it is a PITA to fix..I know I have done it a few times ....and MAYBE the next time I will FREAK out and do it ...( I really like your 1994 by the way ) I seen it on other sites....But when mine flipped out the first time .....I replaced EVERYTHING.... changed filterbowls 3 times ..etc.etc.etc. on a VAN...not fun....BUT ...after I did that no more BS....Regular Service....No problems solid 65 psi ...all day ...even when it is cold....Like it is here ....But I feel you ....And I will have Stage 1's soon....
As for injector health.. part of my recently peaked interest in injectors is that when i cold start it (15-35*F) it smokes fairly good on warm-up and can run a LITTLE choppy for a few minutes before it smooths out.. I have also noticed that my injectors are WAY louder(warm or cold) than my two buddies OBS trucks, both of theirs have 200K + on them and mine has 130K I'm not sure if louder is good or bad? Mine definitely has more power than either of their trucks though.
ok, back to injector hour
If your injectors only have 130k on them, they should be in fine shape unless it's had water run through the fuel system a bit and/or had terrible oil in it. Anyways, you'll be fine with the stock fuel system and stage 1 or 2s. Just know that towing with stage 2s and a stock turbo does pretty well suck unless the tuning is pulled WAY back.. Hell even stage 1's with the stock turbo sucks when towing, but you can at least flip to a stock tune and it will run like a stock truck at that point.
