5.0L Short Block Replacement Time Lapse
Cylinder Bore distortion Ford is calling it, I believe it had to be something to do with it being a sleeved engine and the alloy mixture of the sleeve. The 5.0l also had a issue where the sleeve would be loose in the block, right there that is an issue with a transfer of heat by itself plus the noise it caused.
I am quite sure that by 2013 it is fixed. All these issue are common to the early engines and have since been worked out. Even so you have 60k miles to figure it out and even if you go over that mileage within 5 years of your model year Ford will help out with the cost as a Goodwill they call it where they do cost sharing with the dealer. Ford is very good about that from the cases I have seen at my dealer.
My uncle had a 02 Harley Davidson F150 that around 80K started having issues w/noise coming from the engine that hadn't been there before. I don't remember the details of the situation, but I remember the dealership replacing his engine at no cost. That was the first Ford he had ever purchased and has purchased nothing but Ford since for him and my aunt.
73 Comet GT
02-29-2008 10:03 PM
71ranchero500
07-14-2003 06:36 PM
Racerdave
06-27-2003 09:32 PM
