1988 Hard to shift out of park
I had an issue where I pulled up to a red light, had to do something so I put my 95 van in park, then when I was ready to take off I could not get the van out of park. After messing with it I finally got it into drive. The issued was some wiring to the brake. There is a sensor attached to the brake pedal so when you step on the brake you can use the shifter. In my case the sensor was fine, it was the actual wire connected to the sensor that was an issue and when manipulated the right way it worked.
2803JW
11-12-2018 09:54 AM
Spoongooner
2004 - 2008 F150
09-01-2008 02:10 PM
EZTrader
1978 - 1996 Big Bronco
09-09-2003 05:03 PM
