'02 Power Fold/Telescope Mirror Swap
I did a heck of a lot of reading on various forums last fall and finally finished my install project. Figured the majority of it out using a thread here and another on a different forum. Hopefully this is an acceptable first post as I tend to lurk & read for the most part. This project all started because of a broken bottom glass in my factory towing mirrors and what the charge for a replacement..then snowballed when the idea of defrost mirrors came about. Overkill is underrated anyway!
A friend helped me with the bulk work of the wiring which was a major pain, we fashioned the switch bezels out of the OE bracket the switches came in & mounted the radar detectors mute button where the original switch was. Because of the location of the new switches we had to delicately massage the door support to allow the door panel to sit flush again. Done again I think you could push them a little farther to the right in the panel and avoid this but we didn't account for the pig tails in mock up.
Overall it was a big headache but worth the time. It has made driving around town a lot more enjoyable with the bigger glass, defrost in foul weather, & fold for wonderful folks in parking lots. Biggest irk of the whole project was how much that dang relay from Ford costs that allows the fold to function.
Thanks!
Much appreciated!
Thank you!
It is. Luck of the draw as to whether you get the power fold mirrors with that feature if buying used like I did, not all of them have them and I couldn't find an OE mirror number for the ones with that feature.
Much appreciated!
Thank you!
I have them, just didn't think of using that function. Never saw the switch before, but I know it requires a drivers seat module if you use the feature. where did you find the driver seat module and switch? I put my 08+ mirror switch in my old mirror switch hole, and put the extend right below it as I don't have a crew cab and have more room in the bezel. Was gonna wire them tomorrow.
As a side note the '09+ mirrors have heated top AND bottom glass. I found that out searching and decided if I were spending the money that is what my truck was getting.
Nice job. I too have an '02 that I installed '08 mirrors on a few years back and have never looked back (pun intended). A couple questions on the heat switch; 1) similar year as the mirrors or truck? 2) is it a timed switch or straight on/off? I currently run a on/off rocker switch and want a timed switch.
Thanks and again very nice job.
P.S. Thanks for the info on '09 having heated spots I may have to upgrade to them.
No problem at all. I would hate for someone to go out and buy a set of mirrors not knowing, when either one typically costs the same.
I looked up the part number I bought for the rocker switch and it is from a '95 Mercury Cougar or Ford Thunderbird so my original post was mistaken. The switch is timed, somewhere in the 10-15 minute range I have never timed it.
Far as looking back goes I got scolded at a young age for not using my mirrors buy an old cowboy at a horse show. One of those things that sticks with you for whatever reason
Also have a '51 F1 with a hopped up flat head lurking about
